Table of Sprinter switches for the Sprinter's console:
http://homepage.mac.com/ipolyi/Lola/AI/20050507/Sprinter_Switch_Table.pdf
Unfortunately, that's not all of them. There's more but I haven't had the time to research for the p/n's.That is all of them?
http://www.sprinter-source.com/forum/showpost.php?p=4101&postcount=20did you happen to have the part number of the cargo lamp switch that fits?
Is this the switch you're using?I ended up getting the 3 position Sprinter fan switch.
I am planning on using it with the fantastic fan since I already installed the heater booster switch to control the aux heater...
I'm thinking of running optocouplers to make the on/off and intake/exhaust functionality work.
I ran Cat5, so I can't run any meaningful current on those wires...
any thoughts?
George, connect 12V to the DPDT relay and use GND to enable the relay. So, connect GND to the switch from the console somewhere, and connect the switch output to the relay. 1 wire used.i was thinking or running the power from the fan down to the switch and then back
I figure I can make the exhaust function the default with a dpdt relay to reverse the polarity going to the fan direction switch
2 wires used so far
I believe the vent/fan switch is active low, meaning you supply a GND to it to open the vent cover.the I use the same power wire to close the dome switch whenever the dash is not in the neutral position
