Allantuttle1
Art wagon 1
On acceleration.
Hello, I've got a 2006 140" with 198000 on it. The Vibration does go away when I let off accelerator. Seems to happen between 2200rpm and 2600 rpm. Which is about where it settles on the interstate. I don't go over 2200rpms while I'm trying to get to the bottom of this.
I crawled under the van to check for play in the UL joints I can wiggle the driveshaft but the only play I see is at the back of the tranny. Sounds like I am moving gears inside of it. Is this a major issue? I searched the forums and found similar but none that quite described my issue.
I will add that I sometimes feel what feels like UL play but overall the transmission is smoth and normal. Light RSN on deceleration.
On the phone with two separate shops.....they say its usually the carrier bearing and both shops have never done a driveshaft.
Any ideas?
Allan
Any ideas?
Allan
