Old 03-31-2018, 11:29 PM   #1
Trebor Retsruw
Default Alcoa Duea Bright Aluminum rims
Has anybody had any experience with installing Alcola Dura Bright aluminum rims on a Sprinter 3500 DRW RV?
Trebor Retsruw is offline   Reply With Quote
Old 04-01-2018, 05:56 PM   #2
73shark
2011 AS Interstate (sold)
Default Re: Alcoa Duea Bright Aluminum rims
I think that's what Airstream puts on the Interstates.
73shark is offline   Reply With Quote
Old 04-01-2018, 06:21 PM   #3
TOASTER.13
Lots of people with LTV Unity and Serenity RVs had Alcoa wheels installed as an option when their unit was delivered.
TOASTER.13 is offline   Reply With Quote
Old 04-02-2018, 03:17 AM   #4
Boxster1971
2012 Sprinter 3500 Ext
Boxster1971's Avatar
I have Alcoa wheels on my Interstate based on the 3500 dually Sprinter. Mine are pre Dura-Bright so they have to be polished to look good. I understand the new Alcoa Dura-Bright finish is very durable. Wish I had it on my wheels.
FYI- Advanced RV also installs Alcoa wheels.
You can read more here:
https://www.arconic.com/alcoawheels/...bright-evo.asp
- - Mike
2012 Sprinter 3500 Extended converted B-Van by Airstream
-- Mike
2012 Sprinter 3500 EXT Airstream Interstate
Boxster1971 is online now   Reply With Quote
Old 04-03-2018, 03:26 PM   #5
hein
Van Guru
Sometime ago, our Alcoa wheels were shinny. They don't look as good now but still a great wheel for a Sprinter 3500. Unless things have changed, you can't put one on the inside in back due to wheel thickness and length of the studs. We have the OEM steel wheel inboard. We went up a tire size as well to an LTX 235/85. Great smooth ride but we also have full air suspension in the rear (no leaf springs) and Konis all around.
2010 MB 3500 RV conversion.
Old 04-03-2018, 03:33 PM   #6
hoosierrun
I believe the newer LTV dually's have an aluminum inside wheel, but it is not the shiny bright aluminum.
In any case, you probably want to buy the Borg solid stainless steel valve stems (comes in a kit) if you ever intend to install TPMS sensors.
2016 Leisure Travel Vans, Serenity
hoosierrun is online now   Reply With Quote
Old 04-03-2018, 10:35 PM   #7
Boxster1971
Alcoa has actually redesigned their wheels to allow using two in dual positions. They have tried to keep up with changes made by Daimler Vans over the years. Here is a link to the relevant Alcoa bulletins. First two listed are about Sprinter 3500 wheels.
https://www.arconic.com/alcoawheels/...-bulletins.asp
-- Mike
