Old 03-25-2013, 03:32 AM   #1
sailquik
sailquik's Avatar
Default 2012 Sprinter ASR + Michelin LTX MS2 tires= Awesome!
Just finished a 77 mile drive through blowing snow, icy mix, 32 deg. F from I-64 in Hampton, VA up Rt. 17 to Tappahannock, VA. Deepest snow was about 6-8" but even that had cars upside down/ spun into the median, 4x4 upside down in the median, the Sprinter just kept on going like it was on rails.
Now I know why I paid the $$ for Michelin LTX MS2 tires. They rock when you really need to get somewhere.
Not sure the traction control ever really kicked in....didn't see any flashing triangles.
Whew, 30-35 mph for 77 miles can wear you out!
The Following 3 Users Say Thank You to sailquik For This Useful Post:
alan_f (05-08-2013), Eric Experience (03-25-2013), hein (03-29-2013)
Old 03-25-2013, 09:06 AM   #2
glojo
Default Re: 2012 Sprinter ASR + Michelin LTX MS2 tires= Awesome!
Great news and it shows how wise it is to have the right tyres for the conditions. No one likes to hear, 'If only you had fitted......'
Well done
John
glojo is offline   Reply With Quote
Old 03-25-2013, 12:05 PM   #3
flman
In Transit
I put them on one of my Jeeps, never had it out in the snow, but they are some quiet running, easy rolling tires!
Old 03-25-2013, 02:37 PM   #4
WPJ
Great news, I have the same ones and they were great this winter..
2013 2500 Passenger Wagon aka The BEAST, 144" High-top Loaded
GTA - Greater Toronto Area
WPJ is offline   Reply With Quote
Old 03-29-2013, 02:56 PM   #5
hein
Van Guru
I had just purchased some tires when I saw this thread. So I went back and had them put on the Michelins. More $$ but a much better ride. I went with a 235/85 R16 on my 2010 3500
Old 03-29-2013, 03:18 PM   #6
WPJ
Van looks sweet, I don't know how you did it but you made artic white look cool.
Old 03-29-2013, 03:57 PM   #7
sailquik
sailquik's Avatar
hein,
Are those Alcoa forged rims?
You are running steel rims on the inside rears, or did you find a way to extend the
rear wheel studs?
Your Sprinter is looking GOOD!
You have a 170" wb short back right?
Old 03-29-2013, 04:01 PM   #8
hein
Van Guru
Thanks for the positive comments on the look.
Yes, those are Alcoas with OEM steelies on the inside. And, yes, it's a short back (not extended).
2010 MB 3500 RV conversion.
sailquik (03-29-2013)
Old 03-29-2013, 04:07 PM   #9
sailquik
sailquik's Avatar
hein,
My Sprinter should look so good!
Was there any issue with the stud length?
I haven't looked at the Alcoa rims since I had the '06 T1N and wanted a full set, but the
T1N read studs wouldn't work with the rim thickness in the bolt pattern area.
Do you have the "polished both sides" Alcoa rims, or do you have to remount the tires all the
time to rotate them every 10K?
What is the rim width on your rear Alcoa rims....Do you have an invoice with the Alcoa Part Number?
Thanks,
Old 03-29-2013, 04:59 PM   #10
'06 sprinter
Those ltx's are great I've ran them on every work van I've had, wear like iron to. I have 25k on the rear of my 3500 and just got new fronts, maybe 3/16" difference in tread height. You should get 100k out of a set easily so the price difference is a wash because you would go thru two sets of different brand tires in that time. Can't wait for my crappy goodyears on my Sierra to wear out to switch to michelins
'06 sprinter is offline   Reply With Quote
