Old 06-14-2019, 03:37 AM   #1
billintomahawk
'02 2.7 T!N Freightliner
Default Tank-A Re-purposed Van build - Input Appreciated
Some history. $360 usd, included a full tank of fuel.
Would not restart when hot.
A low scream coming from the belt pulley area.
200 miles from home.
Just the usual stuff. New belt, tensioner, pulleys, water pump, alternator. Radiator, transmission lines, oil change, transmission servoced, etc,etc. Three dead mice in the heater blower fan box blew the thermal fuse on the speed control.
Replaced and working fine now
bill in tomahawk
billintomahawk
2002 T1N Freightliner
OM 612 2.7L
Transporter 1 Neu 154HP
2500 140"WB, low top
Tank, the repurposed van
billintomahawk is online now   Reply With Quote
The Following User Says Thank You to billintomahawk For This Useful Post:
ranchworld (06-14-2019)
Old 06-14-2019, 04:12 AM   #2
billintomahawk
Default Re: Tank-A Repurposed Van build
More.
[IMG]https://photos.smugmug.com/Sprinter-build-out/i-6dNNp6X/0/88948ac5/XL/IMG_4571-XL.jpg[/IMG
Slowly we turn....
bill
billintomahawk
OM 612 2.7L
Old 06-14-2019, 04:32 AM   #3
billintomahawk
Is there no end?
New tires from Walmart.
Oversized Hankook brand. $60 each mounted and guaranteed anywhere in the USA-Walmart.
Free rotation. Run at 42 psi, he's a big cushion.
Junkyard ladder $10, welded feet onto latter $30.
Junkyard windows from old RV, $20 each.
Holes cut with a angle grinder and a jig saw.
bill
billintomahawk
OM 612 2.7L
Old 06-14-2019, 04:44 AM   #4
billintomahawk
Winter is coming fast...Heat was need.
bill
billintomahawk
OM 612 2.7L
Old 06-14-2019, 04:59 AM   #5
ranchworld
'06 158 2500 Passenger
Nice work Bill.
Old 06-14-2019, 05:06 AM   #6
billintomahawk
A little more to come before I fall out the back of the van and break my right hip.
bill
billintomahawk
OM 612 2.7L
Old 06-14-2019, 05:23 AM   #7
billintomahawk
Gotta have a refrigerator white boy.
So right about here I broke my hip falling out the back doors onto frozen ground.
Snap!
Then a long drag to the house and an ambulance and surgery and two months at my friends place on crutches.
The sawbones told me I had the hips pf a fourteen year old girl and that the bones were healthy so he pined my hip, no replacement parts. New old stock.
Like the van I am repurposed.
In desperation I bailed for Florida to get out of the ice and snow.
Those aren't my legs.
I went with what I had handy, a single bed and a hotplate.
It seemed like recovery took forever but it happened. The crutches became a cane and then the cane was left behind.
Now the build starts in earnest.
bill
billintomahawk
OM 612 2.7L
elemental (06-14-2019)
Old 06-14-2019, 07:39 AM   #8
Mickyfin
Mickyfin's Avatar
Wow, inspirational to say the least.
Old 06-14-2019, 02:06 PM   #9
johnshmit
johnshmit's Avatar
Did you fix your "no start when hot" issue?
https://www.ebay.com/itm/Fuel-Inject...75.c100623.m-1
johnshmit is offline   Reply With Quote
Old 06-14-2019, 05:13 PM   #10
billintomahawk
Yes, there was air in the lines caused by a leaking fuel filter.
I replaced the OEM water separating filter with a Baldwin filter without water separating ability(fewer places to leak) and redid all the connections with new clamps and hose where necessary.
Mostly I cut the rotten ends off the cloth covered hoses and got them well clamped. The problem went way and I saw no air in the clear line to the low pressure fuel pump. "02-3 years have a suck system different from '04 on.
It has not returned in 5k miles.
bill
billintomahawk
OM 612 2.7L
