michaelbarton
Hi all
I have 2007 315cdi sprinter...no start condition. Live scan shows that rail pressure builds to 360 bar in around 5 seconds and when i stop cranking it drops to 13 bar (actually i think it goes to zilch). Leak off test on injectors shows that they are not firing.. I suspect the fuel solenoid. When cranking it leaks at 360 bar.. is it true that when cranking, the fuel solenoid should not pass any fuel at all ? and also is it likely the ecu is not firing the injectors due to the rail pressure fluctuations..
Thanks in advance
Mike
Thanks in advance
Mike
