EXTERNAL 12 VOLT OUTLET
jonesboy
Got a 2015 313 CDI ex Apollo rental which is in the process of being sold.
There is a 12 volt plug on the rear left side near the water inlets.
The only thing lacking is volts - nothing is happening!
I have searched for a fuse without success.
I assume that the unbranded fuse boards under the drivers seat would be the likely suspects but they all seem OK.
Any suggestions as to where this fuse could be skulking?
Somehow I misread your original post as 120V not 12V. My mistake.
said the only thing lacking is volts,
Then said that you run your toaster and jug (whatever that is- coffee pot?).
seems like a bit of contradiction there.
That said, you have a 12V toaster and jug?
Anyway, I would probably try to trace the wire.
Good luck.
So are you saying it used to work but now doesn't? If so you're looking for a fuse somewhere in the circuit!
If it has never worked then seen as it is next to the water inlets maybe it is for a water pump to transfer from a water carrier?
